1997 Chrysler Sebring STARTING
100,000 MILES • 6 CYL • FWD • AUTOMATIC
LIGOH
OUR 97 SEBRING CONVERTIBLE WON'T START. WE THOUGHT IT WAS THE BATTERY, BUT IT WON'T START WITH A FULLY CHARGED BATTERY. IT TURNS OVER,BUT WON'T START. THE CAR HAD BEEN SITTING ON OUR CARPORT IN FLORIDA FOR APPROXIMATELY SIX WEEKS.
Mar 29, 2008 at 1:09 AM
  • 75,988 POSTS
Try doing below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump and listen to the injector/s are they pulsing.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Mar 29, 2008 at 1:49 AM
