1997 Chrysler Sebring STARTING
LIGOH
  • 1997 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 100,000 MILES
OUR 97 SEBRING CONVERTIBLE WON'T START. WE THOUGHT IT WAS THE BATTERY, BUT IT WON'T START WITH A FULLY CHARGED BATTERY. IT TURNS OVER, BUT WON'T START. THE CAR HAD BEEN SITTING ON OUR CARPORT IN FLORIDA FOR APPROXIMATELY SIX WEEKS.
Saturday, March 29th, 2008 AT 8:09 AM
Try doing below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump and listen to the injector/s are they pulsing.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself, distributor pick-up, control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Saturday, March 29th, 2008 AT 8:49 AM
