I have a 97 sebring i t will shift to 4th gear ,but will slip off to 3rd gear and stays there what can i do.
Apr 21, 2008 at 6:09 PM
✓Experienced Mechanic
Hi there,
First thing to do is have the shift pressures and line pressures tested, his may indicate to the tech and problems with in the trans, you could try doing a service first, change the oil & filter but i feel it is a deeper problem you are looking for.
