1997 Chrysler Sebring pressures
BAB43
Air Conditioning problem
1997 Chrysler Sebring Two Wheel Drive Automatic 115000 miles
When I checked the pressures the high is 150psi and the low is in a vacuum, ??
Dec 14, 2008 at 2:24 AM
  • 75,988 POSTS
I assume you're checking the engine compression what was the low reading. A compression gauge measures pressure and a vacuum gauge read the vacuum in inch/mercury-0-30. A good compression should be atleast 20% + or - from the highest-
Dec 14, 2008 at 2:48 AM
