1997 Chrysler Sebring NO FIRE OR INJECTOR PULSE
1997 CHRYSLER SEBRING
190,000 MILES • 6 CYL • FWD • AUTOMATIC
T.J. IANNACONE
Car was cut off and would not start back up. Had a 2 mis fire codes. Checked for spark and did not have. Checked for injector pulse and did not have. Tried a used distributor and controller and did not change. Does it have a cam sensor and how do you check the crank sensor to see if it is operating correctly?
Jul 19, 2010 at 1:31 PM
Start by testing the ASD relay, then the CPS and CMH
Jul 19, 2010 at 6:31 PM
T.J. IANNACONE
What is the ASD relay and location? What is the CMH and location?
Jul 19, 2010 at 10:34 PM
The CMH is the camshaft position sensor you test the same way likethe CPS.
The ASD is the automatic shut down relay (2.5L) located On cowl, at left rear of engine compartment
Jul 20, 2010 at 7:48 AM
T.J. IANNACONE
How is the propper way to check the cam and crankshaft position system?
Jul 20, 2010 at 9:17 AM
Go this link: http://www.youtube.com/watch?v=RtqeOYNgn8A
Jul 20, 2010 at 11:36 AM
