1997 Chrysler Sebring Idles poorly, stalls at low end, runs
13,500 MILES • 6 CYL • FWD • AUTOMATIC
SCRAMBLUR
I have replaced several items, i.e. idle control motor, plus, wires, cap and rotor. I have also replaced the idle temp sensor, the EGR. We now have all the codes cleared, but the problem persists. I had a shop do a diagnostc scam and they tell me that #5 cylinder is not firing and possibly the distributor needs replaced. Any thoughts?
Apr 15, 2010 at 1:57 AM
ERNEST CLARK
  • 1,730 POSTS
Check to see (listen) if the #5 injector is firing. If not, first make sure the connector/wiring is ok. If so, then replace that injector.
If it is firing, do a balance/drop test for that injector. It could be clogged or just bad.
Apr 18, 2010 at 12:46 AM
