1997 Chrysler Sebring Idles poorly, stalls at low end, runs
SCRAMBLUR
  • 1997 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 13,500 MILES
I have replaced several items, i.E. Idle control motor, plus, wires, cap and rotor. I have also replaced the idle temp sensor, the EGR. We now have all the codes cleared, but the problem persists. I had a shop do a diagnostc scam and they tell me that #5 cylinder is not firing and possibly the distributor needs replaced. Any thoughts?
Thursday, April 15th, 2010 AT 8:57 AM
ERNEST CLARK
  • 1,730 POSTS
Check to see (listen) if the #5 injector is firing. If not, first make sure the connector/wiring is ok. If so, then replace that injector.
If it is firing, do a balance/drop test for that injector. It could be clogged or just bad.
Sunday, April 18th, 2010 AT 7:46 AM
