After 3 hours of messing with the powersteering pump and the hidden bolt in the back that wasnt in the manual(thanks haynes) I finally got the car all back together belts tensioned properly and the car wont start. While messing with the powersteering pump I snapped the main fuel feed to the injector rail. Replaced line have pressure and have spark car will not turn over. If it was a tps or crank sensor it would not spark correct? Openned timing cover belt looks fine. HELP?
SPONSORED LINKS
Tuesday, December 2nd, 2008 AT 10:02 PM
