1997 Chrysler Sebring engine performance
277,603 MILES • 6 CYL • FWD • AUTOMATIC
CHRISTOS99
don't know the history of the car.can barely get the engine to run no power very hard to rev up pops and backfires almost like its missing .what i have done so far ,compression is good 125 lbs visually checked fuel spry pattern from each injector OK approx 50 psi. have replaced distributor. have slight seepage on cyl leak down test .checked timing marks all 3 marks lineup. would appreciate any feedback or incite you may have on this particular problem thanks.chris
Mar 4, 2008 at 11:46 AM
BMRFIXIT
  • 19,053 POSTS
Do a vacuum test
if its low
check the catalytic converter
and exhaust back pressure flow
Mar 4, 2008 at 12:49 PM
