My odometer and tachometer quit and then come back on sporadically
Oct 16, 2009 at 9:29 AM
✓Experienced Mechanic
There are a few things that can cause this. A bad vehicle speed sensor, loose wiring behind the dash, or the inst cluster is going bad. Start with the easiest. Check for loose wiring harnesses behind the dash.
