1997 Chrysler Sebring
187,000 MILES • 6 CYL • 2WD • AUTOMATIC
JDR9280
I have a 97 Sebring and for a while every time i would shift to D position it will vibrate inside. However when i let go of the break and step on the gas the vibrate stop, but when I hit the break to stop it will vibrate even when is idleling. I check my breaks and they are all fine.
Apr 8, 2009 at 3:53 AM
JDL
  • 16,098 POSTS
Maybe the vibration is an engine misfire/vacuum leak? How long since a tuneup? Are there any troublecodes? Some of the national brand autostores will check codes for free, if the key cycle method doesn't work.
Apr 8, 2009 at 4:09 AM
JDR9280
There is no codes and last week I change the motor and transmission fluids, all the filters and the sparks plugs. I also check to see if there are no vacuum leaks and there is no misfires. The car does run great it just that annoying vibration when I am waiting on a stop and when I put it into drive other than that the car is fine. All the other gears I get no vibration.
Apr 8, 2009 at 7:53 AM
JDL
  • 16,098 POSTS
Check the idle air system, if the problem is only at idle?
Apr 8, 2009 at 8:06 AM
