1996 Chrysler Sebring Tune-Up problem
150,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRYSLERCHIQ
I had a tune-up done 2 weeks ago and now I have a missfire already. The car is missing when I drive it so I returned it to the place that did the tune-up. They said oil had leaked on the plugs so they put a valve cover on it. However they kept the plugs in there with the oil still on it. Was that dumb, should they have replaced them or at least got the oil off? I know nothing about cars and I really need help!! Any advice please...
Mar 6, 2008 at 10:19 AM
SERVICE WRITER
  • 9,123 POSTS
Were wires done also?
Is it still with a miss?
Mar 6, 2008 at 10:21 AM
BMRFIXIT
  • 19,053 POSTS
Very common for the valves to be leaking oil
as for changing the plugs again there is no need for that
but the oil should be removed and cleaned
good luck
Mar 6, 2008 at 10:26 AM
CHRYSLERCHIQ
Yeap I got new wires and plugs but the valve cover thing didn't work either, the car still drives as if it has a misfire. Some guy said I may need a distibutor cap & rotor, but I'm scared to drive it. If I continue to drive I think I may screw up other stuff on the car. I recently had a water pump put on along with a audio system, but that shouldn't make my car drive bad should it? I asked my husband but he doesn't know what the hell he is talking about :)
Mar 7, 2008 at 9:17 AM
SERVICE WRITER
  • 9,123 POSTS
When you originally took it in, did you ask them to diagnose the misfire? Or was the partial tune up in hopes of tixing it? Valve cover gasket will prevent the wires from going bad due to oil contamination, but will not solve a misfire.
Have this diagnised by some one (a shop) that is capable. "one guy says" is going to get expensive. Maybe it is a cap and rotor, but misfires can be caused from much more that tune up related problems. No one likes to pay for diagnosing, but it usually cheaper in the long run .
Mar 7, 2008 at 9:43 AM
