1996 Chrysler Sebring Trying to pass smog
193,000 MILES • 6 CYL • 2WD • AUTOMATIC
PUMANP81
My 1996 Sebring LXi will not pass smog due to a functional Check failure... Smog place told me that it could be due to my cars computer needing an update... It appears that the cars computer is not holding the memory... does anyone have any ideas what might be causeing this problem??
Thanks
Nov 24, 2008 at 9:38 AM
BMRFIXIT
  • 19,053 POSTS
What do u have for codes ?
monitors not ready ?
they had a recall to flash the PCM and some needed to be replaced
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 24, 2008 at 11:23 AM
PUMANP81
I dont have any codes it is not showing any codes and nor is my check engine light on...
I called the dealer about a recall and they said they have no recalls for my car..
Nov 24, 2008 at 4:15 PM
BMRFIXIT
  • 19,053 POSTS
Was the battery disconnected or work was done on the car recently?
Then u had failed because monitors not ready
what the emission report read ,
the reason of failure ?
car need to be driven up to a 100 mile or so after disconnecting battery and or clearing codes
Nov 24, 2008 at 10:02 PM
