1996 Chrysler Sebring Steering Wheel makes noise.
68,000 MILES • 6 CYL • 4WD • AUTOMATIC
LDSROGAN
When I turn the steering wheel fast, it makes noise like rubbing rubber sounds.
how can I fix it??
May 17, 2008 at 10:14 PM
BMRFIXIT
  • 19,053 POSTS
is it coming from the bottom at the firewall if so you may spray WD40
if inside the steering check the clock spring
May 17, 2008 at 11:28 PM
