1996 Chrysler Sebring Heater
1996 CHRYSLER SEBRING
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
GLENTPAGE
I have a 1996 Sebring, heater fan does not work in lower settings,also only works in defrost mode,any suggestions?
I changed relays under hood fuse box, but still not working, although relays were not clearly marked for heater fan.
Is there another relay somewhere else? or is it another fix?
Oct 30, 2008 at 9:06 AM
GLENTPAGE
I replaced the fan switch resistor. It was located under and behind glove box. This fixed the fan switch problem.
The system is still stuck in defrost mode. The guy @ auto parts store said it may be the contol box located within the dash. Any ideas? The dash looks like it would be difficult to take apart, and I would be worried that I may break something when taking apart.
Oct 31, 2008 at 7:29 AM
