1996 Chrysler Sebring Engine will not turn over.
BARBARA COOK
Engine Mechanical problem
1996 Chrysler Sebring 6 cyl Two Wheel Drive Automatic
I have been unable to start the car for about one year. I have replaced the battery, 2 months ago and the starter this past weekend. The convertible window switches sound as if they are kicking in but are not working, the lights etc are working. How can I find out if the engine is seized or if there could be a electrical issue?
Jul 7, 2010 at 8:04 AM
  • 75,988 POSTS
What is it doing? Cranking over and will not start or just won't crank at all/nothing when your turn the key to starting position, also do you see all the idiots lites that normally comes on, when key at On position???
Jul 7, 2010 at 8:47 AM
BARBARA COOK
The idiot lights come on when the key is in on position. The starter clicks but the engine will not turn over no response.
Jul 8, 2010 at 12:30 AM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be a blown fusible link the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note: If it doesn't apply disregard.
Jul 8, 2010 at 6:29 AM
