1995 Chrysler Sebring P0304 CODE
10,000 MILES • 6 CYL • FWD • AUTOMATIC
DAPSRUS
I just started at trying to clear a recurring code that comes up as soon as i start my car - this code of p0304 - cylnder #4 misfire - have changed plugs / wires / cap- rotor but still it comes back - i was recently told to replace the dstrbutor coil combination at 200.00 bucks ?
help
dave
Dec 22, 2008 at 5:24 AM
ZACKMAN
  • 4,202 POSTS
It is not the distributor. If it is , you will have more than one cylinder misfire. I believe it is your fuel injector.
P0304 Code - Cylinder #4 Misfire Technical Description
What does that mean?
A P0304 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #4.
Symptoms may include:
* the engine may be harder to start
* the engine may stumble / stumble, and/or hesitate
* other symptoms may also be present
Causes
A code P0304 may mean that one or more of the following has happened:
* Faulty spark plug or wire
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector
* Burned exhaust valve
* Faulty catalytic converter(s)
* Running out of fuel
* Poor compression
* Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Dec 22, 2008 at 1:38 PM
