2007 Chrysler PT Cruiser Rumbling sound -under carriage
37,500 MILES • 4 CYL • 2WD • AUTOMATIC
BIGDADDY11
When I travel on uneven roads I hear a loud rumbling noise under the floor when the car is bouncing from the even road surface.
It feels as if I am running over wood logs. This noise is different then the customary noises one would hear when they are traveling over ‘bumpy’ roads.
Apr 13, 2009 at 7:10 AM
CARADIODOC
  • 34,413 POSTS
Kinda low mileage, but you might look at the rubber inner anti-sway bar bushings. Any play between the bar and bushings will make a dull thumping noise, not a metal-on-metal sound. Also look at the exhaust system for hangers or pipes hitting the floor or frame.
caradiodoc
Apr 13, 2009 at 7:37 PM
