Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
PT Cruiser
Climate Control
Air Conditioner
Pressure Sensor
2007 Chrysler PT Cruiser no a/c
2007 CHRYSLER PT CRUISER
50,000 MILES • 4 CYL • FWD • AUTOMATIC
WAGONER RADIATOR
MEMBER
1 POST
Have no power to the pressure switch! Does it have a a/c relay and where? And if not that then what?
Aug 9, 2010 at 4:40 AM
KHLOW2008
Experienced Mechanic
Hi wagoner radiator,
Thank you for the donation.
The A/C high pressure switch receives its power from the PCM, terminal C1 ( Light Blue/Orange wire).
Check for continuity between the wires and if continuity is good, you could have a faulty PCM.
Aug 9, 2010 at 6:45 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
