I have a 2006 PT Cruiser and need to replace the radiator.
One instruction says disconnect the A/C line bolts from the condenser with the line bolt wrench after draining the A/C of all freon. This evacuation must be done by a licensed mechanic, and most shops will do this without charge. Set the lines aside so they are not in the way. And unbolt the radiator assembly from the top frame mounts, and it will slide out toward the top of the engine compartment. The "radiator assembly" is the twin-core main radiator, the A/C condenser, and the fan housing. These are one complete unit and must be removed as one piece.
The other instruction doesn't mention disconnecting the A/C line bolts but does say to take off the fan housing separately. Do I really need to evacuate the A/C?
Jan 23, 2010 at 5:05 AM
