Remove 6 way power seat switch
39,421 MILES • 4 CYL • FWD • AUTOMATIC
HILLCHARGER5
I just discovered that the drivers seat outside panel on my Cruiser was broken. When reading online forums this is an apparent problem. But I have a new one on order, so my only concern at this time is removing the power seat switch from the broken panel. Looking at the back of the panel shows that this switch just snaps in, but it has a large knob on the outside that must be removed to allow the switch to be removed. I am sure that these switches are expensive so I don't want to break the control knob off.
Any help is appreciated.
Thank you for the help.
May 13, 2010 at 4:45 AM
BMRFIXIT
  • 19,053 POSTS
Here is a guide on how to change a seat switch with diagrams and instruction below to help you change it out on your car.
https://www.2carpros.com/articles/seat-position-switch-replacement
REMOVAL
Disconnect and isolate the battery negative cable.
Remove two screws to left cushion side shield.
Disconnect wiring from switch.
Remove attaching screws and switch from bezel.
May 13, 2010 at 11:49 AM
HILLCHARGER5
Jack O good evening, the problem that I am experiencing is that the large control knob on the outside of the seat trim does not allow removal of the switch. This switch snaps in place from the back side of the seat trim, no screws. I don't know if this knob attached via a barb type of attachment or there is some other type of mechanism holding it in place. If I am able to remove the knob from the front of the seat trim, the switch may be easily removed from the back side of the seat trim.
Thank you again for your help.
May 13, 2010 at 12:17 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_7830a_thumbnail_6.jpg
are we talking about the same switch and if so the should knob pop out
May 13, 2010 at 1:09 PM
HILLCHARGER5
Jack O, good morning, your photo looks exactly like the problem switch. I will carefully try to pop the knob off.
Thanks a lot for the support....
May 13, 2010 at 11:57 PM
HILLCHARGER5
Jack O, info worked perfectly!!!
Ed
May 14, 2010 at 12:12 PM
BMRFIXIT
  • 19,053 POSTS
Thank you !
May 16, 2010 at 10:57 PM
CHRISMOO
I have the same problem with the broken swithch mounting/bezel but I cannot find the actual replacement part - do you have the part number od actual name so I can look it up?
Hope you can help and thanks in advance!!
Chris
[quote:9b0d36cd40="hillcharger5"]Interior problem
2006 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic 39421 miles
Thank you for the help.[/quote:9b0d36cd40]
Jun 16, 2010 at 3:45 AM
BMRFIXIT
  • 19,053 POSTS
its about $25 many on line part stores has it
AIRTEX / WELLS Part # 1S8904 More Info {#4602697AA, SW6372}
Left
Jun 16, 2010 at 4:46 AM
CHRISMOO
Ah sorry for my confusion.
I am after the plastic trim/bezel that houses the switches, etc, not the actual switch.
The plastic lugs that clip it to the seat snapped, sucky design it seems.
Thanks for the quick response, hope maybe you can help on the triim too!!
Jun 16, 2010 at 4:50 AM
BMRFIXIT
  • 19,053 POSTS
sorry dealer item
special order
or used parts store (not with this design they all brake )
you can try
good luck
Jun 16, 2010 at 4:56 AM
CHRISMOO
Agh, guess that is why I cannot find it.
Thanks for the speedy response, really appreciate it!
Jun 16, 2010 at 4:58 AM
