2006 Chrysler PT Cruiser electrical
23,300 MILES • 4 CYL • FWD • AUTOMATIC
PATRICIA WILSON
I have an electrical issue in which the cars power door locks, windows, gas gage, and odometer do not work. I had a friend check the fuses and they look clean.
You can see I have low milage. I bought the car used from a used, in 2007 from a car dealership at 9,000 miles. I have used the car mostly fo inner city driving.
I will say that the only presign of this issue has been that the car window have gone down on there own not realizing that could have been a problem. The two time were about a year apart when I was driving all of a sudden heard street noise and the right back car window was down. I did not put it down. Might not have any connection but thought I would mention it. Also, I do not have my car with me and do not know what wheel drive tyoe it is. But added front wheel just to fill the blank.
May 4, 2010 at 8:46 AM
  • 75,988 POSTS
Hi patricia wilson, Welcome to 2carpros and TY for the donation
You have a multiple issues here and its not gonna be easy to fix over the net
For the window/door problem:
Your possibilities here could be the totally integrated power module, front power window switch
Fuel level -check and test the fuel pump/level sensor module
Odometer could be the odometer itself if the VSS is working properly
May 4, 2010 at 12:03 PM
