2006 Chrysler PT Cruiser
317 MILES • 4 CYL • FWD • AUTOMATIC
CROTTSCUSTOMS
my car is gettng the right fuel pressure and is firing fine , but want start. any sugguestions?
Jan 31, 2010 at 7:39 AM
  • 110,246 POSTS
If you have spark and the fuel pressure is good, it should run unless the timing is off, there is low compression, of the injectors are not working. Have you checked the injectors?
Feb 12, 2010 at 11:52 AM
