2005 Chrysler PT Cruiser Runs Hot
85,000 MILES • 4 CYL • FWD • AUTOMATIC
CRASHDRIFTER
2.4L T E Engine runs hot during operation after 15 min. Fan on full, new t-stat, no signs of compression in collant. Oil clear, no steam exhaust. Acts as if the WP is loosing block pressure. IS this common. Any PSI specifications with t-stat open?
Aug 27, 2010 at 12:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
cooling system should maintain pressure between 14 - 18 psi
Aug 27, 2010 at 12:35 PM
CRASHDRIFTER
Have you heard of issues with with the WP impeller slipping on the shaft? It's obviously a big job just to check?
The engine ran up to 230+ F in the shop (Stall) with only one or two bubbles in an isolated water bottle (Radiator cap on-vent to atmosphere). I really have a hard time believing the head gasket is causing the WP to cavitate and result in loss of block pressure.
Aug 27, 2010 at 12:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
no haven't heard that issue, the most common issue on these is the cooling fans will burn out and cause overheating. haven't had any with that issue before though.
Aug 27, 2010 at 1:28 PM
