2005 Chrysler PT Cruiser power steering fluid
55,000 MILES • 4 CYL • AWD • AUTOMATIC
KYLE052302
I have a power steering fluid leak, by driving it am i causing damage to this? And if not, how long can I drive like this? (money isues right now)
Jan 25, 2009 at 12:03 PM
BMRFIXIT
  • 19,053 POSTS
The problem will start if you run the system dry (out of fluid )
will cause the pump to seize …………
make sure you always adding and keeping an eye on the fluid level
and if so you should be OK until ready to repair
Jan 27, 2009 at 9:58 PM
