2005 Chrysler PT Cruiser Fuel system cleaner & replaced
51,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNNYPRO
When car is in park I step on the gas pedal all the way to the floor and the rpm gauge will not go over 4000 rpms and sputters and flutters! Is it a turbo issue or does it need new coil wire for the plugs?
Jan 2, 2009 at 10:03 AM
BUDDYCRAIGG
  • 2,262 POSTS
it's probably because the rev limiter will not let it go above about 3500 when in park.
Jan 2, 2009 at 1:08 PM
JOHNNYPRO
The car even does it when its in drive! Nevermind. You have been absolutley no help but thanks anyway. The car isn't going to sputter and miss fire from a rev limiter. When I first got the car you could rev the engine all the way up and red line it if you wanted to!
Jan 2, 2009 at 2:03 PM
BUDDYCRAIGG
  • 2,262 POSTS
I'm sorry you are dissatisfied with our service.
you did not indicate that you had a problem while driving or that you had a misfire in your first post.
does it have a miss fire at idle?
so you could do a load balance test to narrow down the bad cylinder?
has your check engine light come on?
Jan 2, 2009 at 2:13 PM
