2005 Chrysler PT Cruiser crossed cables
CLILSHORTYO16
Electrical problem
2005 Chrysler PT Cruiser 4 cyl Two Wheel Drive Automatic
When i changed my battery i crossed the cables and now the radio doesn't work but the lights on the radio work and the reading light doesn't work. Also where the mileage is located it says no fuse. I checked all of the fuses and they are good. I am pretty sure there is a wiring problem somewhere but I don't have a clue where to begin looking. I read another faq about this and it said i may have to take the car to the dealer to have the radio reset but #1 i don't have any money and #2 why would the reading light be out. Anything may help me. Thanks for your time.
Jan 29, 2010 at 10:49 AM
CARADIODOC
  • 34,411 POSTS
Did you check fuses in two places? There should be a junction box in the dash board and a power distribution box under the hood.
There are two power sources for the radio. One is turned on with the ignition switch to turn the radio on, and one is always hot to maintain the station presets and clock memory. The memory circuit is always tied to another circuit that is always live, such as the interior lights.
Normally, connecting the battery backwards can do many thousands of dollars worth of damage. There are dozens of computer modules, and the alternator that must be properly powered.
caradiodoc
Jan 31, 2010 at 1:06 AM
GENIALYNNMACHADO
I have the no fuse on my car as well I left it alone it does do anything to my car and for the fuse for the radio go to the box under the hood MD look for the fuse that say idiot or so its yellownd its the only one that has a clip over the whole fuse its self try to lift it up wth the screw driving the ones u use for the glasses nd that should solve the radio if not jst don't plug in the fuse I hve the same problem so I jst unhooked it nd now the raodo fine
Jan 2, 2013 at 7:20 AM
