Oct 13, 2010 at 3:00 AM
RLEACH6
MEMBER
how do i change the fuel filter on my 2003 chrysler pt cruiser. Where is it located at and why dont they sale just a fuel filter?
Apr 2, 2019 at 12:31 PM
(Merged)
✓Experienced Mechanic
The fuel filter is part of the fuel pump to replace it you must drop the tank and remove the fuel pump here is a guide to help you see what you are in for when doing the job.
Cheers
Images (Click to enlarge)
(Merged)
RLEACH6
MEMBER
they are saying that there is no secondary fuel filter on my car,
(Merged)
CARADIODOC
Nope that is the only one this car has which is normal for many cars build past 2000
(Merged)
2CP-ARCHIVES
MEMBER
how do you replace the fuel filter?
(Merged)
JDL
The fuel filter mounts inside the fuel pump module. Is non serviceable part. Have to replace the fuel pump module, according to my info.
(Merged)
S.BOONE
MEMBER
1 POST
Engine Performance problem
2004 Chrysler PT Cruiser 4 cyl Two Wheel Drive Automatic ???? miles
How do you change the fuel filter on an 04 Chrysler PT Cruiser?
(Merged)
SERVICE WRITER
You don't change it as maintainence. It is part of the fuel pump module. Very pricy and very questionable when it comes to design.
It is located in the fuel tank.
(Merged)
SCOTTNDANIELLE
MEMBER
2005 pt criuser fuel pump is working but no gas to motor
(Merged)
SCOTTNDANIELLE
MEMBER
droped gas tank turned key and it sounds like it is suckin air or something but not in lines and can not find any holes or tears
(sorry wanted to add that info)
(Merged)
Remove fuel filter and test pressure, no flow faulty pick up or crushed fuel line, flow at filter check system up stream for faults.
(Merged)
SCOTTNDANIELLE
MEMBER
Thank you I have dropped the gas tank and the fuel pump is working pulled the codes and got p 0340 said it was the camshaft positioning sensor replaced that and still no luck read online that it could be the timing belt it is getting fire don't know where to go from here. anybody have any suggestions.
