2005 Chrysler PT Cruiser ac vents out comperssor releif val
68,000 MILES • 4 CYL • FWD • AUTOMATIC
BECKER R
ac quit cooling and saw white smoke come from under the car. checked when got home and the compressor was kicking in and out a few times and then vented out the releif valve
Sep 12, 2010 at 12:50 PM
ERNEST CLARK
  • 1,730 POSTS
there's either an obstruction in your system or the compressor has failed.
The only way to know for sure is to place a gauge manifold on the test ports and isolate the system components.
If you think you can tackle this yourself, I'll walk you through it. But unless you're already familiar with A/C systems, I really don't recommend you mess with this yourself, as it's very complicated.
Sep 17, 2010 at 12:02 AM
