I've had my 02 since it came out, normally the revving or high idle usually happens when the pcv valve is bad on it, mine was cracked and the idle changed when I was driving, sometimes even when I stopped and what cut off the engine. Cheap part too, like 2 bucks. Easy fix, if that's what it is, not sure what else it could be. If it turned out to be something different let me know.
Thanks,
Anthony
SPONSORED LINKS
Saturday, July 17th, 2010 AT 1:24 AM
