2004 Chrysler PT Cruiser Rough Running
2004 CHRYSLER PT CRUISER
82,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCONNORS11
Ok, I have changed the wires, plugs, air filter, and ignition coil. Still getting the code for cylinder misfire. What else can I do before I take it to a dealer. Thanks for your help
Nov 16, 2009 at 6:01 AM
SCONNORS11
I found out that I had a burnt valve. Took it to the Chrysler dealer and they wanted over 2500.00. I had a friend to do it for 1300.00 and he changed timing belt, waterpump, and thermostat along with valve. Run like a champ now. All this started with a misfire in the #4 cylinder.
Mar 2, 2010 at 11:31 AM
