2004 Chrysler PT Cruiser oil pan
MPH702911
Engine Performance problem
2004 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic
does anyone know what metal the oil pan is comprised of? is it mounted directly under the engine? and is there a mounting bar under the pan?
Jan 7, 2009 at 11:59 AM
  • 110,246 POSTS
Hi:
The pan is a standard carbon steel construction. It's mounted to the bottom of the engine and is mounted to the engine with aprox 10 to 20 bolts.
If you have other questions, let me know.
Jan 12, 2009 at 9:16 AM
