2004 Chrysler PT Cruiser help
2004 CHRYSLER PT CRUISER
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
RUDYESE
HI I HAVE A 2004 PT CRUISER , ENGINE LIGHT CAME ON I PUT THE SCANNER AND CYLINDER 4 MISFIRE CAME ON . I CHANGE MY SPARK PLUGS AND CABLES. AND IT SEEMS LIKE IS GOING 2 TURN OFF ! THE LIGHT DIM ! I CHECK THE BATT. AND ALTERNATOR AND THEY ARE GOOD ! WHAT CAN IT BE?
Nov 2, 2008 at 1:17 PM
  • 110,240 POSTS
Hi:
After replacing the plugs and wires, does the engine run correctly? As far as the dim lights, are you refering to the headlights? Have you checked all grounds, and battery terminals? This problem sounds like a ground problem.
Let me know what you find.
Nov 12, 2008 at 11:48 AM
