2004 Chrysler PT Cruiser GUAGES
2004 CHRYSLER PT CRUISER
67,000 MILES • 4 CYL • 2WD • AUTOMATIC
ACCPTMTG
gas and engine temp gauge randomly go crazy, needle bounces up and down, alarms go off indicating low gas, high engine temp, when tank is full, engine is cool. Check engine light also goes on. There are times when no lights are on at all, all is quiet. mechanic verified engine temp and things under the hood look good while gauge is acting up, alarming. Tank is definitely full when gauge indicates empty.
Feb 20, 2010 at 3:14 AM
ERNEST CLARK
  • 1,730 POSTS
Anytime your check engine light comes on, have your computer scanned for codes.
Your gauge cluster module could be faulty, or your Body Control Computer could be going bad.
Begin by checking your gauge cluster for loose wires/connectors. Also, on the back of the circuit board you'll find resisistors soldered in place. Sometimes these work loose. Check these with your fingers for looseness. If you find any, you could solder them back on or replace the unit.
If your gauge cluster checks out, then have your BCM checked. Don't just replace it. Have it checked.
Feb 23, 2010 at 10:56 PM
