2004 Chrysler PT Cruiser getting in to replace the gas gaug
2004 CHRYSLER PT CRUISER
36,000 MILES • 4 CYL • FWD • AUTOMATIC
LIBBY250
does any body out there know how i can get into my dash assembly to change my gas gauge bulb ?
Dec 26, 2009 at 6:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
disconnect and isolate battery negative cable.
remove instrument panel top cover
remove steering column cover
remove left instrument panel end cap
grab sides of instrument cluster bezel and gently give a quick pull to unsnap cluster bezel
disconnect turn signal lamps from instrument cluster bezel
remove bezel from dash
remove four screws to the instrument cluster and pull straight back to release off of self-docking connectors.
now you have access to the bulbs.
Dec 26, 2009 at 6:55 AM
