2004 Chrysler PT Cruiser front noise
2004 CHRYSLER PT CRUISER
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICK HIGGINS
I have a 2004 PT cruiser 2.4 ltr turbo high output.The front end is making a grinding noise and even worse when it is raining or when making a left hand turn.Any Idea what is wrong.I have had the front brakes replaced and also the rotors.I am on a fixed income but as soon as I can I will make a donation
Jul 24, 2009 at 11:29 PM
2TXNS
  • 5 POSTS
Does it make the noise all of the time or mostly when accelerating and/or left turns. Mine did and it was the motor mounts that needed to be replaced. While having the motor mounts replaced it is a good time to have the timing belt and water pump replaced, too. As they have to drop the motor from the car chassis to do the motor mount work.
Jul 25, 2009 at 5:10 PM
