2004 Chrysler PT Cruiser FIRING ORDER
109,000 MILES • 4 CYL • FWD • AUTOMATIC
YODA74
We just had our engine rebuilt. 2.4 non-turbo. they put it in, got everything hooked up, got the firing order looked up, but it is back firing???? Any suggestions. thank you, april
Jul 29, 2009 at 2:48 PM
  • 75,988 POSTS
Backfiring while being crank over or backfiring while engine is idling
Feb 4, 2019 at 9:41 AM
YODA74
It is backfiring while cranking over
  • 75,988 POSTS
Valve and Ignition timing could be off-valve sticking
YODA74
could it be the sensor? we read on here last night about the "air gap" in the sensor. we bought a new one today to put it in, but it doesnt have the guage or whatever it is to put in there and no instructions. I cannot get a repair manual for this car as they do not make one. PLease help!!
YODA74
A guy told us the timing is off, how do we reset the timing belt to line up correctly.
  • 75,988 POSTS
You need to put the engine no.1 piston on its compression stroke/TDC and line the camshaft/s and crankshaft sprocket
