2003 Chrysler PT Cruiser Removal of front hub
52,000 MILES • 4 CYL • FWD • AUTOMATIC
ALWAYS BROKE
How do you remove front hub?
Mar 16, 2009 at 7:48 AM
  • 110,248 POSTS
Hi:
removing the hub is involved and I recommend getting a manual with step by step instructions and pictures to identify parts. The brake assembly, rotor, ball joints... all need removed then you can remove the axle and unbolt the hub.
Mar 19, 2009 at 3:45 AM
