Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
PT Cruiser
Drivetrain
Bearing Hub
Replace/Remove
2003 Chrysler PT Cruiser Removal of front hub
2003 CHRYSLER PT CRUISER
52,000 MILES • 4 CYL • FWD • AUTOMATIC
ALWAYS BROKE
MEMBER
1 POST
How do you remove front hub?
Mar 16, 2009 at 7:48 AM
Experienced Mechanic
Hi:
removing the hub is involved and I recommend getting a manual with step by step instructions and pictures to identify parts. The brake assembly, rotor, ball joints... all need removed then you can remove the axle and unbolt the hub.
Mar 19, 2009 at 3:45 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
