2003 Chrysler PT Cruiser RADIATOR
SPRING805CREEK
  • 2003 CHRYSLER PT CRUISER
Engine Cooling problem
2003 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic 120.00 miles
HOW DO YOU FLUSH THE RADIATOR
Tuesday, May 20th, 2008 AT 9:26 AM
BMRFIXIT
  • 19,053 POSTS
Drain down coolant system
enough to add flush
run engine with heat on
until normal operating temp reached
shut engine off and
allow to cool down
drain all coolant
fill with water and run for few and then drain
add coolant
Wednesday, May 21st, 2008 AT 6:47 AM
