2003 Chrysler PT Cruiser New brand of tires and rims on PT
2003 CHRYSLER PT CRUISER
31,000 MILES • 4 CYL • FWD • MANUAL
O3PTGT
Bad situation: Hit a pothole and bent as well as cracked a pair of PT GT chrome rims. The PT held up as far as the wheel alignment went (0.13 out of alignment -well within tolerances) but the rims were goners. (17 x 6 classic 5 spokes)
Decided to replace all the rims with a set of custom rims (Sport Edition CD 17" x 7.5") with a 35mm offset. Was hoping to do all four but had to back order two rims. Was using Bridgestone RS750s but got a nice deal on Bridgestone Grids 019 (17").
New Problem: The new tires (both on front end) will give a minor vibration at speeds greater than 60 up to 70MPH. Both have been on a high end wheel balance machine. What is causing the vibrations now?
Mar 20, 2009 at 5:28 PM
BMRFIXIT
  • 19,053 POSTS
1st rotate the tires and check if vibration moves with the tire rotation
recheck the balance
check CV axles and bearings if not
Mar 20, 2009 at 10:56 PM
