2003 Chrysler PT Cruiser head gasket replacement
2003 CHRYSLER PT CRUISER
48,000 MILES • 4 CYL • 2WD • AUTOMATIC
CFARROW81
today i replaced a head gasket, and now the car turns, but no fire!, sparks and fuel manifold pressure is good.......help me out if possible please chris041981@aol.com
Jun 22, 2008 at 1:08 AM
STACYBECKELHEIMER
Make sure the coil connector and the camshaft sensor connector are plugged into the right place thay are the same and if they are reversed it will cause no fire... this is one solution i found as i am going through the same issue unfortunately this was not my solution so i think i am going to be tracing a lot of wires down.. I am going to start with s106 splice and working my way through the harness from there.. please update if you discover a solution
Feb 24, 2013 at 3:21 AM
