2003 Chrysler PT Cruiser Engine oil and Antifreeze mixing t
2003 CHRYSLER PT CRUISER
160,000 MILES • 4 CYL • 2WD • MANUAL
SANTI1701
I bought one engine at a salvage yard...the first one was cracked under the oil pan. Salvage yard replaced it. The second one started mixing oil and Antifreeze together...now I am stuck with that engine as the salvage will NOT change it...can this be repaired??? The heat tab are still in tacked on the engine...salvage yard says that I overheated it...I differ with him as I pulled over and turned the engine off when the needle started to rise...it did not get passed the 3/4 mark from mid-range. The BBB and BAR says that if I did overheated the engine that the heat tabs that the salvage yard put on the engine would have fallen off the engine....where do I go from here. I am retired Military with a Mom who is blind, a child with cerebral palsy...need help...Thanks
Sep 2, 2010 at 2:57 AM
ERNEST CLARK
  • 1,730 POSTS
well you definitely have a bad motor. Either your head gasket is blown or there's a crack in the head or block.
You can retain a lawyer. They will eventually held accountable, but it will take you a few years.
My best advise is to go through a reputable shop to purchase used engines, as they depend on their reputation for business and will have suppliers who back their sales.
Sep 17, 2010 at 12:06 AM
SANTI1701
Thanks, for your response, I have turned the case over to the Attorney General of Tucson, AZ...waiting for them to process the case...will keep you posted.
Sep 17, 2010 at 1:29 AM
ERNEST CLARK
  • 1,730 POSTS
No problem. I hate crooked mechanics, because they make us all look bad.
If you need more help, feel free to ask.
Sep 17, 2010 at 10:18 PM
