2003 Chrysler PT Cruiser Dashboard Lights
POOH18MI
Interior problem
My dashboard lights where the speedometer and fuel gauge are, are going out..I was wondering if this is easy to fix (e.g replacing bulbs) or if it was going to be more difficult?
Jan 12, 2010 at 6:15 AM
ERNEST CLARK
  • 1,730 POSTS
You have five bulbs that illuminates the inside of the instrument cluster. Then each indicator (high-beam, turn signal, warning lights, etc.) have their own illumination.
The instrument cluster turn signals and the high beam indicator are serviceable indicators The instrument cluster must first be removed to replace the high beam indicator. Then the defective bulb and socket turns out counterclockwise. The instrument cluster bezel needs to be removed to access the turn signal indicators. If any of the other indicators are burned out, the entire cluster must be replaced.
The five bulbs that illuminates the inside of the cluster are serviceable and may be replaced once the instrument cluster is removed.
To remove your instrument cluster, you first have to remove the plastic bezel. This is held in place with plastic tabs. (Care must be taken to not break these tabs during removal)
Then the instrument cluster is held in place by four screws.
Installation is the reverse of removal.
If I've helped you, please vote for me as my reputation pays my bills. Thanx, Ernest.
Feb 12, 2010 at 11:34 PM
