2003 Chrysler PT Cruiser check engine light
2003 CHRYSLER PT CRUISER
55,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVIDBOSOX
i have hed my vehicle completey maintained, run through diagnostics, and i still have a check engine light. Does anyone know how to reset this so the indicator goes away?
Mar 29, 2009 at 12:49 PM
CARADIODOC
  • 34,373 POSTS
When the light is on it means the engine computer has detected a problem and is trying to tell you that. A mechanic can retrieve the diagnostic fault code that will indicate the circuit with the problem. This has nothing to do with maintenance or lack of it.
caradiodoc
Mar 29, 2009 at 2:26 PM
