2002 Chrysler PT Cruiser Windows Inop
120,000 MILES • 4 CYL • FWD • AUTOMATIC
ROTTENRALPH
Front windows just stopped working. Lockout doesn't make any difference. Now, they work every 100th time. Seems like electric short. How do I find fault. No fuse found.
Feb 11, 2010 at 9:52 AM
  • 110,248 POSTS
What you need to do is remove the door panel and see if there is a loose connection. Also, make sure there is power to the switch. If there is and no other problems are found, chances are the switch is bad.
Let me know what you find.
Feb 12, 2010 at 11:31 AM
