2002 Chrysler PT Cruiser Replacing a rad
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
CRUISERFAN
Hi. I need to replace the rad in my car but i have never done one on a car with ac. Is it the same, Or do i need to do something Specific?
Thanks
Nov 27, 2009 at 4:15 AM
WEM3
  • 10 POSTS
[quote:0c617a2fdd="Cruiserfan"]Engine Cooling problem
2002 Chrysler PT Cruiser 4 cyl Two Wheel Drive Automatic 100000 miles
Thanks[/quote:0c617a2fdd]
I bought a book from the zone and I just finished rebuiling my engine due to overheating so be very careful that you do not have a bad water pump and or thermostat. As far as I can tell, you will need to remove the a/c condenser from the raditor. you will need to jack up the car as well and put it on stands, all of this after removing the cooling fan, and disconnecting the trasmission oil cooler.
good luck.
Nov 30, 2009 at 1:38 PM
