I bought a book from the zone and I just finished rebuiling my engine due to overheating so be very careful that you do not have a bad water pump and or thermostat. As far as I can tell, you will need to remove the a/c condenser from the raditor. You will need to jack up the car as well and put it on stands, all of this after removing the cooling fan, and disconnecting the trasmission oil cooler.
Good luck.
SPONSORED LINKS
Monday, November 30th, 2009 AT 9:38 PM
