2002 Chrysler PT Cruiser odometer
MK3MACK
Electrical problem
The odometer gages have quit working. everything else still works, like the radio and dome lights. It's just the gages and dash lights. What may be the problem?
Mar 19, 2009 at 3:29 AM
MERLIN2021
  • 17,250 POSTS
You can try a self-diagnostic test. To activate self diagnostic program:
With the ignition switch in the OFF position, depress the TRIP and RESET buttons.
While holding the TRIP and RESET button turn the ignition switch to the ON position.
Continue to hold the TRIP and RESET buttons until the word CODE appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display Diagnostic Trouble Codes (DTC's). If no problem exists, the code 999 (End Test) will momentarily appear. Post the results.
Mar 19, 2009 at 3:36 AM
