2002 Chrysler PT Cruiser lining up timing marks properly
78,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBT W
I have the book on this vehicle and i have done everything by thr book and i cant seem to get this car to start any suggestions would be greatly appreciated
Oct 7, 2010 at 8:02 AM
WRENCHTECH
  • 20,760 POSTS
Did the original timing belt break or jump time?
Oct 7, 2010 at 8:09 AM
DOCFIXIT
  • 18,828 POSTS
Did T-Belt break while engine was running? if yes check compression engine interference type ie. valve bender
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_646.jpg
Oct 7, 2010 at 8:10 AM
WRENCHTECH
  • 20,760 POSTS
This isn't a true interference engine. The pistons clear the valves, however the valves can contact each other if the cams are rotated independently.
Oct 7, 2010 at 8:12 AM
